Great, I just wanted to confirm what coil you had..... If an alternator is coupled up to the battery/load and the battery voltage is rising to 19 volts thats wayyyyyyy toooooooo highhhhh, its internal voltage regulator must be bad (assuming all is wired correct especially the voltage sense circuit) and the battery can overcharge n boil over acid n get ruined eventaually plus YES the points will burn up faster and the coil run too hot
Sounds like your getting there, she sure runs better if when the points break open the rotor tip is where its supposed to be i.e. lined up with a cap pickup leading to wire and plug located in a cylinder thats nearing TDC on its compression power stroke woooooooo hooooooooooo
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
