Re: SA electrical problems...final clarification needed
Posted by Bob M on November 06, 2009 at 10:14:58 from (151.190.254.108):
In Reply to: SA electrical problems...final clarification needed posted by Mark on November 06, 2009 at 10:06:19:
Mark - Both locations for the ballast resistor you suggest will work.
Reason: The resistor, coil primary and distributor breaker points comprise a series circuit. The same current flows thru all 3 regardless of the order in which they are connected.
So you can wire the resistor in whichever location works best for you!
