Posted by Mark on November 06, 2009 at 10:06:19 from (71.30.209.232):
While you learned folks were discussing electrical circuits and so forth, I sorta got lost in the fog. So, I want to know exactly which order the ballast resistor is supposed to be in. I think I understand it to be as follows when using a 12 volt coil:
Battery wire to ballast resistor, resistor wire to + terminal on coil and then - coil wire to distributor.
Is this correct?
I originally thought the battery wire should go straight to the + coil post, then the - coil post to the ballast resistor and from the resistor to the distributor.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
