Re: SA electrical problems...final clarification needed
Posted by ScottyHOMEy on November 06, 2009 at 10:18:14 from (64.222.246.226):
In Reply to: SA electrical problems...final clarification needed posted by Mark on November 06, 2009 at 10:06:19:
Votes right now on that issue are 2-1 in favor of the former.
They all three agree that the resistor will perform its intended function when inline between the battery and the coil.
The learned (and respected) heads are disagreeing over whether that's true if located between the coil and the distributor.
I'd go with what they agree on.
