45' M
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Doug on April 24, 2000 at 11:40:55 from (207.32.44.179):
My brotherinlaw has a 45' M that I can't get to run right.It smokes like unburnt gas and has a miss to it. I did a compression test #1 100psi #2 90 #3 100 #4 90. I set the valves, changed plug wires, re-gapped the plugs, re-gapped the points, checked the air cleaner, cleaned the carb, set the float. With the tractor running I took off one plug wire at a time and found that #2 makes no differance if its off or on, and the other 3 you can tell as soon as you unhook the wire it misses worse. So we took the plugs out again and spun the engine over every spark plug has spark, a real good spark,but when you put them in and tried it again the same thing happens, you can pull #2 plug wire and can't tell a differance.It has a near new dist. cap also. It's getting gas cause the plug is wet with gas when you pull it. The tractor runs good, idles good, its just #2 wont fire with the plug in the engine. This tractor has a magneto. I was thinking of trying one of my M's distributor and coil to see if that makes a differance, Any ideas? Thanks Doug
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
