Posted by cd1 on November 09, 2009 at 16:25:21 from (67.234.156.27):
In Reply to: 656 Farmall posted by Diesel D on November 09, 2009 at 11:36:09:
Erik Dekeyser said: (quoted from post at 00:49:42 11/10/09) Well this is how i check the ta, let it warm up and then take it for a drive,put it in 4th gear run it wide open put your foot on both brakes until the engine comes under load pull back on the ta and still keep your foot hard on both brakes and then push the ta ahead and it should engage instantly and not hesitate. If it does it should be good. Yes you can use it with a bad ta but it will only work good in low. Erik..
if the t/a is out it would work in HI not low. high is direct drive, low is not. a 656 is mechanical disc brake so you will only be able to lug the engine down so far until the brakes may not be able to hold it.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
