Re: Model C Power Loss- Dies Under Load
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Colby Kieffer on April 24, 2000 at 18:41:32 from (216.248.68.23):
In Reply to: Model C Power Loss- Dies Under Load posted by Donald Bolt on April 23, 2000 at 10:48:08:
My grandpa and I own alot of tractors. And along with owning them fixing them is a common thing. You say that the carborator was gone though, so it sounds like you are either geting to much fuel or there is a problem with the fuel air mixture. I would try seting your carborater. good luck
Post A Followup
: Re: Re: Model C Power Loss- Dies Under Load
