Re: Broken Hydraulic Line (Sorry if this is a double post)
Posted by Brownie 450 on November 12, 2009 at 03:35:22 from (66.43.241.141):
In Reply to: Broken Hydraulic Line (Sorry if this is a double post) posted by Pete in Tejas on November 11, 2009 at 20:52:31:
Have you got a parts yard in reasonable driving distance? I believe these lines are silver brazed into the block.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
