Re: Broken Hydraulic Line (Sorry if this is a double post)
Posted by Pete in Tejas on November 12, 2009 at 11:51:09 from (74.232.178.219):
In Reply to: Re: Broken Hydraulic Line (Sorry if this is a double post) posted by Brownie 450 on November 12, 2009 at 03:35:22:
Gap Tractor is right dowm the road, but if I recall, they wanted over $300 For a used assembly. New ones are in the $500 range. My experience on used parts is that they are used "up" and I end up spending almost as much getting the used one to work. Are threaded brazed fittings available? Or maybe I could have the old stems pulled out and just shorten the lines by 1/2 an inch. Looking for any viable solutions at this point.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
