Posted by Seth Boyer on November 12, 2009 at 19:10:39 from (99.195.105.224):
Started to work on this H for a friend this week getting it ready to paint. It ran terribly when we first got it. Wouldn"t start well...idled terribly...had absolutely no power. I rebuild the carb with a complete kit from CIH. Adjusted the tappet clearance, which was way off to begin with. Seemed to run a little better after that. I"ve checked that manifold for leaks and it seems to be OK. The manifold is a cheap aftermarket one though. Tractor has a mag, I put in new points and condensor. Installed new Autolite 3116 plugs and new wires today.
It seems to start a bit better. Problem is now that when idleing it seems to flutter. This is at idle and maybe about 1/3 throttle. At full throttle it runs great. Took it out for a drive and at full speed it"s perfect.
I found that while idleing I can pull the choke maybe 1/4 to 1/2 and it smooths out and idles great. put the choke back wide open and it starts to flutter again and die.
Do I not have the carb adjusted right? I adjusted the governor and double checked the carb float.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
