Re: Farmall H running poorly
Posted by Mike CA on November 12, 2009 at 19:43:40 from (99.28.152.102):
In Reply to: Farmall H running poorly posted by Seth Boyer on November 12, 2009 at 19:10:39:
First, tighten the manifold. I'll bet it's loose. Book calls for 50 foot pounds. See if you can eyeball the manifold gasket as well, it may be leaking.
Then, as Scott said, check the fuel flow. You may have a blockage in the tank, even though the sediment bowl is full of fuel.
