Re: Broken Hydraulic Line (Sorry if this is a double post)
Posted by El Toro on November 13, 2009 at 06:49:08 from (74.103.74.58):
In Reply to: Broken Hydraulic Line (Sorry if this is a double post) posted by Pete in Tejas on November 11, 2009 at 20:52:31:
third party image
Can you post a picture of that block? If you were to use a tap drill & tap you would need to clean out all metal chips so they don't get into your hydraulic system. Any hydraulic shop can make you new hoses and JIC fittings are available
in most sizes. I made this hose with reusable swivel nuts for my hydraulic lift with JIC tube fittings. You can get hoses made with double wire braided constuction where you have extra high hydraulic pressure. Hal
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
