Re: Broken Hydraulic Line (Sorry if this is a double post)
Posted by Pete in Tejas on November 13, 2009 at 07:55:55 from (74.232.178.219):
In Reply to: Re: Broken Hydraulic Line (Sorry if this is a double post) posted by El Toro on November 13, 2009 at 06:49:08:
Connecting is my problem. I have hard steel lines coming into the block, then going out along the sides of the tractor for hardlined front remotes. From 900 miles away, I recall that the box is about 2 inches deep, 3 wide and not quite 4 inches tall. I am now looking at removing the box, if it has no real function except splitting, and use 37 deg flare or compression fittings into a "t".
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
