Posted by VFMerc on November 13, 2009 at 14:50:19 from (98.110.125.83):
I have a 1953 H Model with a 6 volt system, magneto, 6 volt generator and 6 volt regulator (L/B/F) that I recently restored. When I run the tractor the ammeter shows no charging or possibly a very small charge. I've used the trouble shooting guide I found on line but can't seem to determine the problem. When the engine is off and lights are turned on the ammeter shows a discharge. When I start the engine and run at ½ speed or better, and place a voltmeter on the regulator F terminal I get 6.24 volts and the battery shows 6.1 volts. The ammeter shows no charge or perhaps just a little. If I turn the lights on, the ammeter shows significant discharge reading. Is it possible the generator / regulator is not putting out enough current to override the battery voltage?
I reversed the wires on the ammeter and confirmed the needle will swing to both sides of the "0". I pretty sure I've got everything wired right. I'm stumped.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
