Re: H Model Ammeter shows no or very little charge
Posted by rvirgil_KS on November 13, 2009 at 16:30:11 from (205.162.222.242):
In Reply to: H Model Ammeter shows no or very little charge posted by VFMerc on November 13, 2009 at 14:50:19:
The regulator connections would be
L (load) goes to hot side of light switch (and ignition switch if using distributor)
B (Battery)goes to ammeter
F (Field) goes to Field terminal on generator
There should be an Arm or Gen terminal under the regulator. It goes to armature on the generator. Is this one connected, you don't mention it so I wonder if that is the problem.
The F (field) terminal should vary in voltage. Be more concerned with the Armature voltage as that is the generator output.
With all properly connected, if you ground the field terminal it should show full charge.
