Stuck starter solenoid??? IH 400
Posted by SDE on November 13, 2009 at 17:00:44 from (174.124.8.103):
Left the key on. Battery died. Will not take a charge. Replaced battery. Attached neg first, then positive. Makes a sizzling sound. When full contact is made, the starter engages, with the key off. Remove the power wire on the back of the ignition switch. Still engages the starter. Is the solenoid stuck? The solenoid switch is only a few months old and has not not seen much use. Is it junk?
Thank you
Steve
