Re: Stuck starter solenoid??? IH 400
Posted by pete 23 on November 13, 2009 at 17:14:07 from (173.87.147.73):
In Reply to: Stuck starter solenoid??? IH 400 posted by SDE on November 13, 2009 at 17:00:44:
Examine small wire and terminal on solenoid to see if it is touching battery cable or if it twisted the terminal when you installed . Then remove the wire and connect battery cable again to see what happens. One has to be very careful of all terminals on solenoid when tightening them so they do not turn as that can cause your problem. Not saying it is the case but have seen it many times. I have seen a few tractors self engage starter when they got damp. One 560 ended up in the grove twice for a guy, wire was very lightly touching and when it rained it engaged starter, which in turn provided ignition through the bypass and tractor went several feet till it bumped into a tree.
