Whenever charging or for that matter jumping a battery from one vehicle to another,
ALWAYS CONNECT POSITIVE TO POSITIVE AND NEGATIVE TO NEGATIVE.
It does not matter which terminal is grounded.
Now, for your question.
As was posted it is normal for your tractor to be a positve ground system.
I would recommend you disconnect the battery from the system by disconnecting the positve ground wire and charge the battery overnight using an automatic charger.
Then make sure all connections are clean and secure and you should be good to go. (If all parts are operational)
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
