Good Battery,Bad Battery ?
Posted by John N.B. Pa on November 15, 2009 at 07:35:39 from (98.21.94.77):
Seems like I might have a little problem and not sure if or how to correct the problem, I purchased a Farmall Cub yesterday,would not start with out a little push,any way when I got home, done s little checking , it seems that the negative post is hot and the poitive post is negative, is this normal or did the former owner charge it uo in reverse, if so can I discharge it and charge it the other way?
