Posted by Wardner on November 17, 2009 at 13:06:01 from (4.154.247.82):
What are the chances of finding a good regulator? (some call them "evaporators")
When I bought my W-400 LP ten years ago, the liquid line had been removed. It ran OK on the vapor line but I never worked it hard. Now the vapor side is no good. The tractor will only run if I just barely crack the vapor valve at the tank. Too little fuel is just as bad as too much.
I went to the archives and found a guy who sells overhaul kits. $80 for some gaskets, o-rings, rubber valve seats, and two flat diaphrams. The kit arrived in 3 days and I disassembled the regulator. Lots of rust in there on the low pressure side. I can't understand why that should be so. If they are prone to rusting, why didn't Ensign use stainless steel or brass?
Anyway, the low pressure spring has been reduced to a few unconnected coils. The steel partition plate is heavily rusted. It may not look like much after I sandblast it. The low pressure valve maybe serviceable for now but will eventually need to be replaced.
So the question is: Am I going to luck out and find a good regulator or will they all have one foot in the grave? The damage cannot be determined until the regulator is off the tractor and disassembled.
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only
... [Read Article]
Latest Ad:
[More Ads]
