Re: Optmia Battery
Posted by John T on November 18, 2009 at 20:09:28 from (66.244.97.31):
In Reply to: Optmia Battery posted by Gary Puckett on November 18, 2009 at 19:03:06:
Around here Advanced Auto handles them. The 6 volt AGM has about twice the CCA of many other conventional lead acid batteries (Good if you need to start at extreme cold temps),,,can be used in any orientation,,,,,,no acid spill to worry about,,,,,,,,,BUT they are of course more expensive so its YOUR TRACTOR YOUR CHOICE if they are worth the extra expense to gain a lot more (if needed??) CCA. The Frankster uses them, hopefully he will comment regarding his experience
John T
