Re: Optmia Battery
Posted by jdemaris on November 19, 2009 at 06:34:23 from (67.142.130.15):
In Reply to: Re: Optmia Battery posted by John T on November 18, 2009 at 20:09:28:
Those high cold cranking amp are provided by sacrificing reserve capacity. I'll take a cheaper flooded lead acid battery with more amp hours any time.
I admit I have a bit of negative bias since AGMs have so much hyperbole in their advertising. I've had to change-out many failed AGM battery banks, and convert back to conventional flooded lead acid batteries.
Granted, there are advantages to using AGMs in certain applications. I see little advantage in farm tractors.
