Re: 300U Hydraulic Pump Swap
Posted by pete 23 on November 19, 2009 at 16:31:11 from (173.87.147.73):
In Reply to: 300U Hydraulic Pump Swap posted by Mark Peters on November 19, 2009 at 13:10:06:
You don't need to worry about the timing marks on the pump drive gear. Just put it in any place. You time the battery ign unit by just pulling the drive gear out and put it back in where ever it lines up with pump drive . As long as you align TDC and number one rotor positon you will not have a problem.
