Posted by Pete7 on November 20, 2009 at 16:39:15 from (72.65.36.65):
I am hooking up the headlights on a Farmall 340. Tractor has been converted to 12 volts and the headlights are 12 volt sealed beams. About 35 watts for each of the 2 lights. The switch is a 3 position type (off,dim,bright,rear). Boy,that coiled spring type resistor on the back gets smoking hot when the switch is in the dim position. That got me to thinking that maybe I should be using a different switch, a 12 volt version? And why did they make a dim position anyhow since it just burning off the electric to keep the lights dim. You are still draining your battery so why would you even use that setting? Pete
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
