Re: Headlight Switch
Posted by TheDurk on November 21, 2009 at 23:12:04 from (71.125.67.230):
In Reply to: Headlight Switch posted by Pete7 on November 20, 2009 at 16:39:15:
If you want them brighter, you can go to NAPA and get some aircraft landing lights (same bulb goes in a Piper Cub, but NAPA's are not certified for airplane use) that fit perfectly in the 12V sealed beam housing. You need to beef up the wiring, including the fuse. I did that after I switched to an alt in 2004. They're great. [Note: this tractor has not been on a public road since new in 1966 and has no plans for doing so, unless it runs away.]
The dimmer resistor wire went up in smoke (literally) the day I installed them. It is not missed.
