Farmall M Charging Problem
Posted by John Harry on November 21, 2009 at 03:40:22 from (174.59.1.144):
1947 M , converted to 12v years ago. When running, no matter what rpm, ammeter sporadically pegs to charge side. I metered at battery and voltage runs normal at 14.5 but jumps to 18.5 when ammeter pegs. I am assuming something is shorting out. Anyone run across this problem? Where should I look first?
