Re: Farmall M Charging Problem
Posted by pete 23 on November 21, 2009 at 10:59:26 from (173.87.147.73):
In Reply to: Farmall M Charging Problem posted by John Harry on November 21, 2009 at 03:40:22:
If you have the three wire alternator, if the #2 sense terminal is corroded or loose it will do just that, also where ever this sense lead is connected to, if that checks ok, it would be regulator, like wise if single wire unit , regulator.
