I still cant say if you have a late Ford type solenoid or one like Janicholson mentioned????????
If its the late type AND IT WORKS and is grounded, when you apply 12 votls to the small S terminal THE OTHER LITTLE I TERMINAL IS SUPPOSED TO THEN GET HOT !!!!!!!!!!!!!! Its lil I terminal is (supposed to be) hot ONLY when the solenoid is energized with 12 volts on its S terminal...
A test lamp and multimeter is all you need to check out that solenoid, its NOT rocket science. if its NOT the late Ford type but needs a ground ALL BETS ARE OFF and if I know that then I will guide you different or just do as Jim already told you
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
