Re: Starter solenoid on my 400
Posted by SDE on November 21, 2009 at 11:05:06 from (174.124.8.103):
In Reply to: Re: Starter solenoid on my 400 posted by El Toro on November 21, 2009 at 07:17:57:
I removed the wire that comes down from the ignition switch. Turned the key to the on postion and I have 12 volts at both of the small terminals. This is why I believe the solenoid has a short inside the case. The case is a metal canister instead of plastic like the one in your photo. Is there anything I can do to fix this new solenoid, besides buying another?
Thank you again
Steve
