Re: Starter solenoid on my 400
Posted by El Toro on November 21, 2009 at 16:20:44 from (74.103.74.58):
In Reply to: Re: Starter solenoid on my 400 posted by SDE on November 21, 2009 at 11:05:06:
I never checked for the voltage on the terminal without any machine nuts. I would think it would have voltage present all the time. The terminal with the machine nuts only had voltage when the key switch was twisted to make an engine
start. You don't want voltage on that terminal
all the time as it will keep the starter drive engaged.
I think your solenoid is defective. Hal
PS: If you can access your old solenoid easily you can pull off the wire that feeds battery voltage to your solenoid and check it with a volt meter. There shouldn't be any voltage present until you have someone make an attemot to start the engine. Make sure its out of gear
and the brakes are set. Keep your hands away from the starter drive. The way you've described how the old solenoid is working your new solenoid should work the same way.
