450 LP Revisited
Posted by Blackland Dan on November 22, 2009 at 13:03:09 from (206.248.34.106):
third party image
third party image
I talked to the owner of the 450 and he said it runs fine. The low side of the TA is out.(Surprise) He wants $2500 for it. I went and looked at it and the only thing wrong with the tin is surface rust. One small dent on the grill. Live PTO, no 3 point and he does have the 2 wheel axle for the front also. Rear tires are good, the front one is missing some tread but is holding air. The seat and battery box are good. (again surprise) Not sure about the $2500, though. By the time I replaced the TA and the other small stuff, I'd have $4000 in it. Not sure it's worth it. What do y'all think? Dan
