Re: farmall super c clutch
Posted by Janicholson on November 22, 2009 at 18:16:07 from (64.61.212.63):
In Reply to: farmall super c clutch posted by jim A. on November 22, 2009 at 18:07:06:
If the fingers on the clutch plate are substantially in from where they were, and the clutch adjustment rod needed massive adjustment, I would suggest that the driven disk (friction disk) was put in backwards, the parts can be assembled wrong and if so the drive hub with the springs around it catch on the flywheel and do not release. If this is the problem, you won't be the first to do it. The drive hub is fatter on one side than the other, and must be put on with the hub extending to the rear. Best of luck, JimN
