Re: carb freeze
Posted by pete 23 on November 23, 2009 at 16:16:39 from (173.87.147.73):
In Reply to: carb freeze posted by dirtdog 38 on November 23, 2009 at 14:47:10:
You say you took intake apart, do you mean seperated from exhaust manifold to clean passages around intake (stove) and or repair heat riser. Is spring good and riser working properly. Other wise, if you have the old style double venturi they are nortorious for doing this no matter what you do to manifold. You can replace venturi with single, should have some other jet modification also but venturi in itself will usually eleminate problem.
