Posted by Dr. Bert on November 23, 2009 at 18:03:50 from (72.36.57.58):
I have an M that has an add-on vee belt driven pump to power the power steering. The pump is mounted on the left side up near the front hood latch, and was driven buy a single long vee belt (now broken) that ran from the crank pulley up around the fan pulley and then out to the hydraulic pump. It appears - by eyeballing- that the belt only engaged each pulley about 1/3 of its diameter. Is this sufficient belt contact for the crank pulley to drive the fan and the hydraulic pump? Your opinions-please. And thank you.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
