Re: Vee belt question.
Posted by Bob M on November 24, 2009 at 04:33:15 from (151.190.254.108):
In Reply to: Vee belt question. posted by Dr. Bert on November 23, 2009 at 18:03:50:
third party image
Like Jim says it should work fine.
On the Farmall M-based Trojan "Utility Speed Patrol" graders, a similar setup was employed. An extended length belt drove a live pump that operated the grader's hydraulics.
It apparently worked well as many Utility Speed Patrol graders were built.
