Will add a little more, in case a tractor puller was playing games and put the M tag 50983 D? on the 8557 D throttle body to make it look like a original M carb. If you look in the throat of the 8557 with the venturi out you will see a ledge that opens the top of throat bigger for a bigger butterfly. If its a M throttle body there's no step up. Going by memory I think the 8557 has the number 10 on the butterfly. Remember for sure the M is 12. Venturi size is probably 30 or 32 if the 9 series one is still in it. Depending what bowl or other parts the carb has in it that may be part of your problem. M gasket and manifold probably overhangs the carb throat also, unless they were blended.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
