Re: Farmall M Runs When Choked - Need Help
Posted by D Slater on November 24, 2009 at 06:32:58 from (72.65.155.239):
In Reply to: Re: Farmall M Runs When Choked - Need Help posted by Sparetime on November 23, 2009 at 18:43:56:
After your first post I waited to see if you could find something simple to fix it. Since thats not working out I will add that you may have a carburetor with a mix of parts, or maybe not. From the good information provided in the first post the throttle body you have is from a 9 series carburetor, but if the little tag has the M carburetor # you posted I don't understand it.
Can you tell me what # the throttle butterfly and the venturi has on it? Not the 5 numbers on the venturi, look close for a D27, D30, D32 etc.
