Re: transmission fluid change
Posted by Brownie 450 on November 26, 2009 at 03:42:22 from (66.43.241.141):
In Reply to: transmission fluid change posted by Byron F. Stone on November 25, 2009 at 12:06:10:
I'm not familiar with the 404, but most of IH's other drain/ check plugs take either a 3/8 or 1/2 socket extension to remove. Dig the dirt out of the recess in the plug & the socket should fit right in.
