686 questions
Posted by Don Dittmar on November 30, 2009 at 04:51:52 from (24.247.231.234):
I am working on a late 686 with the german engine and I have a couple of questions.
1) There is a hole under the tractor in line with the hyd filter that spits oil every now and then. any idea what I am looking at here? There are no threads in the hols so I am assuming its a vent of some sort?
2) Tractor has an aftermarket loader and the are feeding the loader valve off of one of the remotes in the back. This is ok, except if you want down pressure off the loader, then it pops the detent on the remote valve. Is there anyplace a can tap into the hyraulics and run direct to the loader valve?
Thanks for all the help
Don
