Posted by Pandora 504 on November 30, 2009 at 09:15:51 from (64.12.116.73):
Had a little bad luck with my stump grinder, bit off a little more that it should chew,slip clutch on pto shaft did not slip when it was supposed to. I heard a breif grinding sound from the engine clutch area,then everything went on to work just fine. Used it yesterday with wood chipper,no problems,no new noises,lucky I guess? My question is,what goes first,the splines on the PTO input shaft,or the females splines in the pressure plate? I put a clutch in it last year but did not replace the pressure plate,looked too good but the splines in the pressure plate were worn some. Any ideas?????? Thanks,Butch
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
