Posted by Wardner on November 30, 2009 at 10:10:15 from (4.154.242.48):
In Reply to: IH 504 Utility PTO posted by Pandora 504 on November 30, 2009 at 09:15:51:
Most likely the splines on the pressure will fail first because there is less material to wear away. The hardness may be at a lower value as well.
However, if it comes to a stripped pressure plate spline, you will need a new IPTO driving gear and shaft. That is the peice you called the input gear.
The good news is that there are some eBay sellers that have that gear listed. They have it titled as a 460 part but I think it may be the same part as used on the 504. You will have to compare part numbers at CaseIH.com. Price should be around $100. Might be an 80% discount from an CaseIH dealer price.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
