Re: Farmall A Tire Size
Posted by gene bender on December 01, 2009 at 07:04:17 from (67.55.226.179):
In Reply to: Farmall A Tire Size posted by Ken D. on November 30, 2009 at 16:06:59:
How did you measure the rim. If you measure outside to outside the rim will be 1inch smaller so a 7in rim will measure 8 overall. The tires you now have will be as close to the original. I have two sets of 8.3s and the fit good on the 7in rim and the 9.5s on the 8in rims also are qgood fit
