Farmall A Tire Size
Posted by Ken D. on November 30, 2009 at 16:06:59 from (71.126.9.145):
Does anyone know the correct original size for the rear tires and rims on a farmall model A? I am doing a restoration. The tires currently on it are 8.3 x 24 and the rims are 8 x 24. The tires say on them that they should be mounted on a 7" rim. The parts section of this website lists 9 x 24 rims for a Farmall A. That rim size would require a larger tire, I assume. Any help with this mess would be appreciated.
