Re: Farmall A Tire Size
Posted by Brad in TX on December 01, 2009 at 07:14:22 from (209.137.232.122):
In Reply to: Farmall A Tire Size posted by Ken D. on November 30, 2009 at 16:06:59:
Ken,
As ScottyHOMEy said you could get them with 8,9 or 10 inch rims but you might want to consider what you're going to be using the tractor for. I've got a couple of A's with 11.2x24 tires on I think 9" rims and one with 9.5x24 tires on 8" rims. For work that requires really slow speeds, the smaller 9.5x24 tires on 8" rims are the way to go. With the taller tires the tractor speed is increased enough to make tasks requiring really slow ground speeds difficult. The taller tires will work better for tractors rides though.
