Re: While we're discussing distillate
Posted by Bob M on December 03, 2009 at 13:16:32 from (151.190.254.108):
In Reply to: Re: While we're discussing distillate posted by bc on December 03, 2009 at 08:10:09:
If the flapper is stuck in the "cold" position the engine will generally require more and longer partial choke until the motor fully warms.
Conversely if it's stuck in "hot" you lose a little power under heavy load. It may also have an increased tendency to knock under heavy load.
Your situation sounds like the carb is set a bit too lean...
