Re: Will a distributor from a 404 work on Farmall 300
Posted by Owen Aaland on December 03, 2009 at 21:22:35 from (65.165.246.148):
In Reply to: Will a distributor from a 404 work on Farmall 300 posted by Dellbertt on December 03, 2009 at 11:28:11:
Jim Becker said: (quoted from post at 16:26:18 12/03/09) The 300 (O dist) max advance 22 at max idle of 1925 rpm. The 404 (AH dist) max advance is 20 at max idle of 2300 rpm. Two degrees isn't very much but you'll have to decide whether it is close enough to suit you. You could give it a couple degrees of advance at low idle. That may make it harder to turn over when starting.
The IH manuals says the the engine should be timed at high idle so the timing is correct at full advance. That way any discrepancy in total advance will occur at low idle rather than at full load.
