Will a distributor from a 404 work on Farmall 300
Posted by Duanes on December 03, 2009 at 11:28:11 from (136.234.40.2):
Can I use a distributor from a 404 on a Farmall 300 without any changes? I had an o symbol distributor on the 300 and I know the 404 is an AH coded distributor are the degrees the same?
Thank you!
