Owen Aaland said: The IH manuals says the the engine should be timed at high idle so the timing is correct at full advance. That way any discrepancy in total advance will occur at low idle rather than at full load.
The IH manual in front of me right now says to set the timing at 0 rpm. It also has instructions for setting/checking at low idle (375 rpm) and high idle. It makes a BIG POINT that if you set timing at high idle, to recheck it at 375 and make sure there is NO ADVANCE at that speed.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
