Re: Towing Capacity of an I-4
Posted by scot in pa on December 04, 2009 at 01:20:41 from (12.171.163.53):
In Reply to: Re: Towing Capacity of an I-4 posted by Drew W. on December 03, 2009 at 20:15:00:
I don't worry about the length of the chain with the SM, but with the 15.5 tires the drawbar is pretty low anyhow. I used to hook to the lift arms when dragging anything with the bigger tractors, but I also lowered them to just above drawbar height. It's amazing what you can pull with a 1566 when you raise the lift arms up where the front wheels come off the ground. Maximum traction is actually acheived when the front wheels just come off the ground, all the weight is on the rear tires at that point.
