Posted by Janicholson on December 04, 2009 at 18:14:27 from (64.61.211.205):
In Reply to: Charging questions posted by J Wilbur on December 04, 2009 at 16:42:12:
By 2 wire, I assume you have connected the #2 terminal to the output post (Big terminal) this sensor wire controls the voltage output at the alternator. If it is connected well, I suspect the regulator inside the alternator to be out of spec. Typical voltage at the battery terminals at 1/2 throttle with the battery charged is 14.2 to 14.6 volts. If you operate a system much higher than 14.6 (maybe as much as 15) it will reduce the life of the battery. The exception would be short run times and cold weather. In which case the drain on the battery would compensate for high charge rates. Before replacing parts, clean all connections to the battery and ignition to Alt and bat to alt wires. Special look at the #2 terminal to output post is warranted. Good luck, JimN
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
